Migrate stored procedure
  • August 25, 2017
  • 6 replies
  • 71 views
danilo_fme
Forum|alt.badge.img+57
Hello,
Is possible in FME migrate stored procedure in Oracle no-Spatial to SQL Server?
I saw any links here about run a procedure, but migrate a stored procedure.
Thanks,
Danilo
Best answer by trentatsafe
Hello @danilo_inovacao ,
As @mark_1spatial suggested with the different languages between Oracle and SQLServer it is not simple. A quick search of the web does yield some possible solutions to migrating a stored procedure from one SQL language to another.
Here is an article that may help get you started:
https://docs.microsoft.com/en-us/sql/ssma/oracle/converting-oracle-schemas-oracletosql
  • August 25, 2017
I can't see that being possible. Different language specifications between Oracle and SQLServer
PL/SQL T-SQL ?
trentatsafe
Forum|alt.badge.img+7
  • August 25, 2017
danilo_fme
  • August 25, 2017
Hi @mark_1spatial and @trentatsafe thanks yours attention and answer with this case.
So, i hope that do this migration is not suitable?
Thanks,
Danilo
trentatsafe
  • August 25, 2017
Thanks,
Danilo
Hello @danilo_inovacao,
That is correct, it is not probable to migrate a stored procedure from database to database when their SQL languages have fundamental differences.
As such, it would be best to rebuild the procedure using the new language for the destination database.
danilo_fme
  • August 25, 2017
Perfect. Thanks!
danilo_fme
  • August 25, 2017
PL/SQL T-SQL ?
Thanks @mark_1spatial
