Microstation DGNStyler
  • September 22, 2016
  • 8 replies
  • 60 views
edvdl
I am currentley using FME 2015 and i want to use dgn styler to , amongst other things, set the color of polygon object to a microstation V8 dgn file.
For some Features i need to set the rgb value, for other features the indexed color from the color table. But in the resulting dgn file i do not see the desired result at all. For rgb values i use , for example 124, 211,64 values, for the indexed color a numerial value from 0-255 range.
What am i doing wrong here ?
Best answer by itay
Hi @edvdl,
In such a case of mixed settings I would advise you to use divide the data into 2 dgnstylers one for a RGB and the second for the color index.
The RGB values are the fme annotation for RGB, which you can calculate from the RGB values as R/256, G/256 and B/256
Hope this helps
itay
Forum|alt.badge.img+18
Hi @edvdl,
Hope this helps
edvdl
  • September 23, 2016
Hi @edvdl,
Hope this helps
Indeed i am using 2 dgnstylers, one for RGB and one for de color indexed. But what do you mean by 'fme annotation for RGB' Now i am using values like '124,211,64' (R,G,B)
itay
FME uses 0.48,0.82,0.25 for 124,211,64
itay
Here is a posted solution:
https://knowledge.safe.com/questions/19482/convert-between-different-color-values.html
edvdl
@Itay, Thank you very much, your suggested solution works perfectly!
  • February 2, 2017
Is it actually possible to set RGB colors directly or it still sets it as closest index color?
itay
  • February 2, 2017
Both are possible but not via the same styler.
  • February 3, 2017
I mean to set RGB values as RGB color not as index color? Because DGN v8 can have either index color, RGB color or colorbook color. I read that there are hidden attributes which is possible to expose that deal directly with the rgb values. Is it so?
But I read also in changelog that in FME 2015:
MicroStation (V8)
  • Added new format attributes to store cell element color as RGB as well as a DGN index number
