Methods to extract Value from Raster for Points faster?
  • February 19, 2020
  • 345 views
bwn
Forum|alt.badge.img+26
I'm nowhere near as experienced with dealing with Rasters in FME than vector data, so I'm looking for corrections/optimisations to my method of extracting Surface Levels from a City-wide 1 metre Raster.
I'm simply feeding the Input DEM Raster and Input Points into PointOnRasterExtractor to extract the Pixel values onto the Point Features. However, this executes far slower than the ArcGIS equivalent 3DAnalyst ArcTool. 77,000 points take over 1 hour to calculate!
The Raster Reader is the ESRI FileGeoDB Raster Dataset Reader.
So:
  • Is this the right Transformer or are there better ones?
  • Should I be pre-processing the Raster with something else before putting it into PointOnRasterExtractor?
  • Are there methods of limiting the Raster Cells to use in PointOnRasterExtractor which may make it faster (even though in theory this optimisation should be within the Transformer itself) by using a spatial comparison beforehand?
bwn
  • February 19, 2020
At the risk of answering my own question, for unexplained reasons PointOnRasterExtractor massively sped up if I instead fed it data from an intermediate transformer rather than straight from the Reader?
For instance, if I use a Blocker like FeatureHolder in between the DEM Raster Reader and PointOnRasterExtractor, then the same number of Points (77,000) will calculate their Raster Values in 50 seconds!!
  • February 19, 2020
That's an interesting observation. If you're able to reproduce it, I'm sure Safe would love to take a look to try and understand why it happens.
fme-phile
  • February 29, 2020
Ran the same process on 160000 points and the process took 50.2 seconds.
I also tried using the 'RasterCellCoercer' on the dem to convert to polygon features. I then connected the transformer to an 'AttributeManager' transformer adding new attribute 'Elevation' and 'Attribute Value': '_band{0}.value'. Next I connected this transformer to the 'Spatial Relator' transformer 'Supplier' import port. and connected the points to the 'Requester' input port. Within this transformer I updated the 'Spatial Predicates to Test': 'Requestor is Within Supplier' and expanded 'Attribute Accumulation' and ticked 'Merge Attributes'. This process took 42.6 seconds.
bwn
  • March 2, 2020
Similarly further testing suggests this may be largely a function of FME WorkBench in 32 bit, in which I was forced to use as the DEM was an ESRI FGDB. There was some weirdness in this though. As above, certain Intermediate Transformers when used allowed the workflow to execute much faster, whereas a direct feed from the FGDB Reader to the PointOnRasterExtractor significantly slowed it down to ~1 hour + other trials/symptoms suggest to me it is memory management related.
With the DEM converted to to FFS and FME WorkBench 64 bit, it is all good. No Intermediate Transformers required, could connect the FFS Reader direct to PointOnRasterExtractor.
