Message or Alert Box
  • September 19, 2013
  • 9 replies
  • 541 views
larryw
I have a simple workbench that does a FeatureMerger, and I would like to get the attention of the user for unreferenced Suppliers.  Is there any dialog that can be opened as part of a workbench?
My workaround will be to write the unreferenced features out to a TX file and launch Notepad with the file using SystemCaller.  Just looking to see if there is something different...
Thanks,
Larry
I don't think this is possible. However, I usually insert a Terminator into the workspace to catch any anomalies in the data. An example would be the UNFILTERED or NOT_MERGED ports, if that would indicate a problem with the data.
You can customize the error message from the Terminator that appears in the log.
David
fmelizard
Forum|alt.badge.img+22
How about twitting it? :)
larryw
Thanks,  unfortunately Twitter is blocked by our firewall.  I need a more in your face notification than a message in the log.  I will do my Notepad work around...
Larry
fmelizard
You could try to use the system caller to make a sound......
dustin
Forum|alt.badge.img+36
I would insert an Inspector from the unreference port.
  • September 20, 2013
It's possible to create an FME dialog box based on a temporary file defining FME GUI Directives, using a PythonCaller.
# Example: Show a message dialog box import fmeobjects   def processFeature(feature):     msg = str(feature.getAttribute('message'))     directives = ['GUI TITLE Message',                   'GUI MESSAGE %s' % msg]     try:         # create a temporary file defining GUI directives.         filename = './fmeguidirectives.tmp'         file = open(filename, 'w')         for d in directives:             file.write(d + '\\n')         file.close()                  # create and show FME parameter prompt dialog box.         dlg = fmeobjects.FMEDialog()         if dlg.parameterPrompt(filename):             # Do something when OK button was clicked.             pass         else:             # Do something when Cancel button was clicked.             pass     except:         # if an error occurred, log the message.         logger = fmeobjects.FMELogFile()         logger.logMessageString(msg, fmeobjects.FME_WARN) -----
  FME GUI Directives http://fmepedia.safe.com/articles/FAQ/FME-GUI-Directives#heading_toc_j_13
If the message can be a unicode instance, see this Q&A: PythonCaller: Use logMessageString Problems with Encoding  https://safe.secure.force.com/AnswersQuestionDetail?id=906a0000000coj6AAA
Takashi
Tips: If your platform is Windows, you can also play a Windows sound.
import winsound
          # Play a Windows sound before showing the dialog box.
        winsound.PlaySound('SystemAsterisk', winsound.SND_ASYNC)
See more information about the winsound module:
35.4. winsound — Sound-playing interface for Windows
http://www.python.org/doc//current/library/winsound.html
Of if you really want to get fancy, use either the win32 API module or the Qt module to get access to a almost limitless amount of dialogs, forms, etc.
David
  • June 30, 2015
Hello,
Is it possible to create a Dialog Box with the log information ?
Also, I tried to filter the log information (in Tools > FME Options > Runtime) but it didn't do anything. It didn't filter anything in the Workspace, nor in the log textfile. Do you know why ?
Thanks!
