Merging two data sets using lookup/contain
  • Jul 13, 2018 12:49 PM UTC
  • 6 replies
  • 92 views
Hi all,
I'm trying to merge two data-sets when they don't have a common field.
What I would like to do is merge them using keywords that I have in one of the lists, so it should be a kind of a Feature merger with "contains" function, but so far I'm not really successful in finding a solution.
Here's an example:
List of IDs and keywords (1st data set): ID Keyword 111 Mc'Donalds 545454 Starbucks 1234 KFC 222 Burger King 343434 Golden Tulip
List of places that I would like to assign ID to (2nd data set):
Place_name ID Mc'Donalds Amsterdam Central Starbucks Airport Stations' KFC Piazza Burger King Amsterdam Golden Tulip Hotel
So in the end it should simply look like this:
Place_name
ID
Mc'Donalds Amsterdam Central111Starbucks Airport545454Stations' KFC1234Piazza Burger King222Amsterdam Golden Tulip Hotel343434
Any suggestions?
Thanks,
Linda
Best answer by stalknecht
Take a look at the following link: https://knowledge.safe.com/questions/38771/can-i-use-a-feature-merger-to-merge-partial-names.html
the InlineQuerier is your friend:
select * from table_a join table_b on table_a.id || '%' like table_b.id || '%'
stalknecht
Forum|alt.badge.img+22
  • Jul 13, 2018 1:01 PM UTC
  • Jul 13, 2018 1:44 PM UTC
Great, thanks @stalknecht!
InlineQuerier is definitely my friend now
  • Jul 16, 2018 10:34 AM UTC
Hi @stalknecht,
I'm running into some issues when using above piece of SQL - to me this seems more like a "begins with..." instead of a "contains" command.
E.g.
"Starbucks Airport" would match when the used keyword is "Starbucks".
but
"Schiphol Airport Starbucks" would not match.
Is there a way to update the SQL string so it also matches words that are found in the entire string instead of only at the beginning?
Cheers,
Ed
stalknecht
  • Jul 16, 2018 11:09 AM UTC
Hi @stalknecht,
E.g.
but
Cheers,
Ed
Correct it should be:
select * from table_a join table_b on table_a.id  like || '%' table_b.id || '%'
  • Jul 16, 2018 11:16 AM UTC
Hi @stalknecht,
That seems to result in an error:
InlineQuerier(InlineQueryFactory): Error preparing database query: near "||": syntax error Unable to execute statement
InlineQuerier(InlineQueryFactory): Database was unable to prepare query 'SELECT *
FROM "Sheet1" JOIN "brands" ON "Name"  like || '%' "brand description" '%' ||
InlineQueryFactory instance was not properly defined. Consult logfile for details.
InlineQuerier(InlineQueryFactory): A fatal error has occurred. Check the logfile above for details
  • Jul 16, 2018 12:34 PM UTC
select * from table_a join table_b on table_a.id  like '%'  || table_b.id || '%'
worked this way
