Merging points based on distance
  • Jan 15, 2020 8:56 AM UTC
  • 382 views
Hello, everyone. I have points (attributes: X, Y, ID) and I want to merge points that are under 50 m distance and new point should have attributes ( new_ID, X, Y, all id of the points from which the new point was created) and if there is a duplicate point, also making one with attributes ( new_ID, X, Y, all id of the points from which the new point was created)
Thanks a lot.
Best answer by ebygomm
One option is to buffer all your points by the required distance, then dissolve the buffered output together, making sure to generate a list when you do this, then a CentrePointReplacer to get back to a point again.
  • Jan 15, 2020 9:03 AM UTC
Have you considered the NeighborhoodAggregator? Make sure to activate "Generate list" to keep the attributes from the merged points.
You can then use e.g. use a CenterPointReplacer to generate a new point in the middle of the merged points.
Forum|alt.badge.img+54
  • Jan 15, 2020 9:12 AM UTC
