Merging 2 attributes into 1 attribute
  • September 13, 2016
  • 1131 views
lazarlubomir
Forum|alt.badge.img+10
Hello,
I solve problem with attribute diversity. I need to merge values of 2 attributes into 1 attribute. Check the pic below please:
I need to get fully filled attribute igds_rotat - so values should be like that:
0
0
0
0
0
0
0
296,67
How can I reach that, please?
Thank so much
Lubo
Best answer by redgeographics
You could use an AttributeCreator or AttributeManager to add them up but it's maybe best to use a conditional value.
So if attr1 has a value that's used, otherwise it'll use the value from attr2 to fill attr1 (and remove attr2 afterwards). This does assume it's always a case of either one of them having a value, not both.
Forum|alt.badge.img+50
lazarlubomir
Thank you, it works!
