Merger informations Oracle and Microsoft SQL Server
danilo_fme
Forum|alt.badge.img+57
Hello,
I'm looking the better way and automatic to do this.
I have two Databases ( Oracle and Microsoft SQL Server Spatial ) and need to compare the datas between the two tables:
The tables has 80 attributes in common ( with the same name ) and need to merger, i think to use the transformer FeatureMerger.
My question is: Need i to select manually in FeatureMerger the attributes Requestor and Supplier to 80 attributes?
*Example with just 3 attributes add manually
Thanks,
Danilo
Best answer by david_r
Why not use the Matcher? In particular, look at the "Attribute matching strategy" setting.
taojunabc
Participant
  • Participant
  • October 11, 2017
If two table have same attribute names and case,You can select the first 79 attributes in Group By,then set Requestor to Supplier with the last attribute. If the attribute names or case of the two tables are different, you can rename them first.
  • October 12, 2017
danilo_fme
  • October 12, 2017
Hi @taojunabc, thanks your typ. It was interesting and its works!
Thanks,
Danilo
danilo_fme
  • October 12, 2017
Hi @david_r,
Thanks your help:)
