Merge tables with no join value
  • May 19, 2021 12:46 PM UTC
  • 429 views
I am trying to merge two tables with no common key. How can I do this?
1 is from a select returning the database name (dbname) and server name (srvname). For example:
BlueSpark, WINSQLPRD001
2 is from a function and returns database role information. Example:
sa, sysadmin
NTSERVICE\\SQLWriter, sysadmin
NTSERVICE\\Winmgmt, sysadmin
NTSERVICE\\MSSQL$INST1, sysadmin
I want to take the two items from 1 and add them to each row from 2 such as:
BlueSpark, WINSQLPRD001, sa, sysadmin
BlueSpark, WINSQLPRD001, NTSERVICE\\SQLWriter, sysadmin
BlueSpark, WINSQLPRD001, NTSERVICE\\Winmgmt, sysadmin
BlueSpark, WINSQLPRD001, NTSERVICE\\MSSQL$INST1, sysadmin
I've tried using various transformers and all require a common key. So I tried converting the results of 1 into attributes and using that to populate the columns of the output, but it creates separate rows with the results of 1 and 2 - they are not merged such as:
BlueSpark, WINSQLPRD001,,,
,,sa, sysadmin
,,NTSERVICE\\SQLWriter, sysadmin
,,NTSERVICE\\Winmgmt, sysadmin
,,NTSERVICE\\MSSQL$INST1, sysadmin
nielsgerrits
Forum|alt.badge.img+67
You can just use a FeatureMerger and put "1" in the Requestor and the Supplier fields.
2021-05-19_15h20_16Set the single record (dbname) as supplier, the other stream as requestor.
