Merge Table Rows
  • May 13, 2020 2:48 PM UTC
  • 90 views
Hi everyone,
A quick, probably very simple, question here.
I'm working with different areas and I have calculated what percentage of a certain area belongs to a certain group. Now, the percentages all have a single row in the attribute table (see picture). I want all the percentages to be on a single row so I can have the percentages per area and make a pie chart with it.
So it should be just one row for the GEBIED = Donzel 1
Hopefully this makes sense.
Thank you in advance for your help!
Best regards,
Esmee
danilo_fme
Forum|alt.badge.img+58
  • May 13, 2020 3:03 PM UTC
Hi @ev2019
I suggest you to use the transformer Aggregator - like configuration bellow:
Thanks,
Danilo
  • May 13, 2020 4:37 PM UTC
Hi @ev2019
Thanks,
Danilo
Thank you! This was exactly what I was looking for!
itay
Forum|alt.badge.img+19
  • May 13, 2020 7:38 PM UTC
Hi @ev2019
Thanks,
Danilo
If you dont have or need the geometry of the features, you can set the mode to attributes only.
