Merge polygons that do not touch/overlap
  • May 6, 2014 2:31 PM UTC
  • 518 views
Hello,
I am looking for a transformer that is much like the "merge" function in ArcGIS. I need to be able to merge two polygons that do NOT touch into one feature. It is possible to do this manually in ArcGIS, is there a way to do this in FME?
I cannot add area to either of the features in order to do this sort of merge (ie: bridge them together with a small polygon), since area is a sensitive attribute for this feature class.
Dissolver did not work! I could only get it to merge polygons that physically touch.
Thanks!
Best answer by david_r
if you want to create multipart features, you can use the Aggregator.
David
  • May 6, 2014 6:09 PM UTC
David
verdoodtdries
Forum|alt.badge.img+23
kduf
Use the HullAccumulator or HullReplacer to merge non-touching polygons into one geometry.
