We face a problem correcting the geometry between multiple polygons in a layer.
There are some gaps between polygons and we need to automatically fill them. We identified 2 ways to fill the gaps between 2 polygons, explained in the following chart.
We tried the first solution using dossolver and Donut Hole extractor, but there are some line left after the process (maybe due to the different positions of the shape vertex on the grid). So we don’t know if our process is the best to succed ? if yes , how to fix this problem ?
