Merge attributes of two excel sheets
  • July 27, 2016
  • 99 views
Hello FME users,
I have two spreadsheet one of them contains phone log information and the other one has caller details with their phone number, attached herewith. I want to merge them into one if their phone number matches. The Phone number is common column between two spreadsheets. Please advise.
Best answer by ryanatsafe
The FeatureMerger is probably what you'll want to use. An overview of this transformer can be found in the FME Desktop Basic training course
http://desktopmanualbasic.safe.com/DesktopBasic5Transformers/5.Exercise3.html
This might also be helpful
Data Joins
ryanatsafe
Forum|alt.badge.img+11
  • July 27, 2016
Data Joins
fmelizard
Forum|alt.badge.img+22
  • July 28, 2016
Data Joins
Also check out the Joiner transformer -- you'd read one of the sheets via a normal FME reader and pipe it into the Joiner, and then in the Joiner, configure for the other sheet.
  • July 28, 2016
I tried Joiner but the results I am getting is not as per my expectations. Maybe I am not configuring accordingly. I want a new spreadsheet with all attributes with both matched phone numbers. Thanks
