MeasureExtractor don't have value
  • Jun 28, 2020 3:13 PM UTC
  • 180 views
Hello.
I have input line data in EPSG:3857. And I break the line data into vertices and get points. (by Chopper)
Next, I use the MeasureExtractor tool in the hope of getting M - values.
However, the tool does not work and issues MISSING_GEOMETRY_MEASURE.
Tell me pls, how can I get m - values for vertex?
Forum|alt.badge.img+54
  • Jun 28, 2020 3:41 PM UTC
If you're line does not have a measure already you will need to generate one before chopping with the MeasureGenerator
danilo_fme
Forum|alt.badge.img+58
  • Jun 28, 2020 10:31 PM UTC
Hi @gellerroma
I simulated your case creating a line with transformer Creator and Chopper.
A PointOnlineOverlayer was used before transformer MeasureGenerator.
FME Data Inspector:
Thanks in Advance,
Danilo
