Measure Inclination Between Features in 3D Space
  • June 12, 2013
  • 34 views
I am needing to find the inclination between features, similar to how the NeighborFinder calculates distance and direction.
When dealing with features in a 3D space though, distance and direction are not enough. Additionally, the distance will be different by measuring to the inclined feature rather than across on a 2D plane.
Is there a way to do this?
Thanks in advance,
Matt
  • June 13, 2013
Hi Matt,
one solution might be to replace each feature with a 3D point, use the ElevationExtractor to get the Z-values, connect the points and then use a LengthCalculator (dimension: 3) to get the length in 3D space.
The inclination can then be found with something like tan? = (Za - Zb) / length.
David
Thanks David. I'm going to give it a go. Who would have thought 9th grade geometry would ever be practical!!
Regards
Matt
  • June 14, 2013
Hi Matt,
Since it's easy to make a mistake in using trigonometric functions, re-confirm carefully the definition of those. I also sometimes get confused ;-)
Takashi
