Maximal rectangle
  • Feb 12, 2015 5:03 PM UTC
  • 135 views
jdh
Forum|alt.badge.img+41
Has anyone implemented an oriented maximal rectangle in FME?  I'm looking for the largest rectangle that can fit within a polygon.
gio
Forum|alt.badge.img+15
  • Feb 13, 2015 12:10 PM UTC
This is more a geometric mathematical problem.
Bruteforce types just itterate over all the possibility down to a certain resolution/accuracy.
One way would be to extract the overal skeleton midline and have a centrpoint travle along it, calculate circel interceptpoints and if there are 4 intercepts, calculate the area.
Another way would create a grid to a certain resolution and look for largest amount of griblocks covering the area whilst being a square as a total.
Finding the exact amximum on a arbitrary polygon however is a tad more complex.
Type in your question and check out the possibilities posed. Better polish up your math though...;)
There are a lot of papers you can download on this issue.
jdh
  • Feb 13, 2015 3:09 PM UTC
I've looked at the "empty rectangle" alogorithms, but they produce an axis aligned rectangle, which is not what I'm trying to get.
