Matching an ID to another data set
  • Apr 4, 2014 10:40 PM UTC
  • 474 views
So,
I have one data set that has some attributes that match another data set, I simply want to find out what records in data set 1 have a matching record in data set 2.
So I have used the "matcher" transformer and a bunch of matched results get spit out of the "Matched" port but only about 60 of them are from data set 1 and when i look at the data and manually search for a match in data set 2 there is not always a match.
This seems to happen in "NotMatched" also. The matcher is clearly doing something i dont understand.
What is that matcher doing to end up with this result?
Is there a way to just have FME report back that X record from data set 1 has a match in data set 2?
Best answer by brettlordcastil
Place an AttributeExposer before your Matcher and expose fme_feature_type. Then on your Matcher, put fme_feature_type under "Attributes That Must Differ". This will prevent features from data set 1 matching each other.
Lastly, since you only want features in data set 1 at the end, route the output of Matched and SingleMatched to a single Tester transformer and test the value of fme_feature_type is only the name of data set 1; this will filter out all of the features from data set 2 that were matched.
Edit: You can also use potentially use fme_basename or fme_dataset may work as well depending on circumstances, but fme_feature_type will probably be more dependable since it will separate out different data layers from the same source file.
  • Apr 6, 2014 5:05 PM UTC
The Matcher compares all the input features. If a dataset 1 feature matched with another dataset 1 feature, they go to Matched port even though there is no matched dataset 2 feature.
The Matcher has many parameters. How did you set them?
Takashi
  • Apr 7, 2014 5:51 PM UTC
You could try the FeatureMerger instead.  I would also have a good look at the data you are trying to compare.  Are they the same case?  (fix: StringCaseChanger).  Are there extra spaces? (fix:StringReplacer).  Just some things to try.
Good luck.
