Mapping null attributes
  • December 24, 2016
  • 11 replies
  • 96 views
arthy
Forum|alt.badge.img+8
I'm doing a lot of point on area overlay and area on area overlays. The values are all coming from an oracle database.
When using the nullattributemapper as shown below
it works.
However, the problem here is that I'm updating another oracle table and this option provides some attribute values to be only an apostrophe (') while I want to have those attribute values being mapped to an empty string.
So instead of choosing map to 'New value', I have tried without success to map those values to 'empty string' and I don't understand what is the issue.
  • December 25, 2016
Hi, what happened when you set 'Empty String' to the 'Map To' parameter?
arthy
  • December 25, 2016
@Takashi, it fails also.
itay
Forum|alt.badge.img+18
  • December 25, 2016
Does the database where the update take place allows for empty values?
  • December 27, 2016
I think it might help us understand your question a little better if you included a sample workspace. For me, it's not quite clear if your trying to map to an apostrophe (') or if the source data has an apostrophe and you want to map to Empty String. It seems like the latter, in which case @takashi suggestion to use Map To: Empty String should work, see the attached example. nullattributevaluemapper.fmw
erik_jan
Forum|alt.badge.img+26
  • December 28, 2016
If you want to write a Null value to the database, you might want to set the NullAttributeMapper to If Null (or empty) then Missing. In that case no value will be written to that attribute in the table.
arthy
  • December 29, 2016
@MarkAtSafe, @takashi
The data source has some <null> values that I would like to map to <empty string> and unfortunately the translation failed.
However, it works perfectly when I set the <map to> parameter of the NullAttributeMapper Transformer to <New Value> with the New Value being set to ''.
My question is why I'm having such issue and how to solve it?
P.S. A simplified version of the complete workspace is available at https://drive.google.com/file/d/0BwjZP-sfazLMZlU5LWR5Nm11eEk/view?usp=sharing
Thanks
arthy
  • December 29, 2016
@itay,
yes it does.
  • December 29, 2016
OK. Maybe I found the issue.
This is a simplified string expression for the SQL statement.
insert into your_table (str_field, num_field) values ('@Value(S)', @Value(N))
Here, if both the "S" and "N" attributes store the <null>, the expression generates this SQL statement.
insert into your_table (str_field, num_field) values ('', )
Naturally it causes a syntax error. The correct SQL statement should be:
insert into your_table (str_field, num_field) values ('', null)
The Oracle writer can generate a correct SQL statement internally even if an attribute contains the <null>, but you will have to build a correct statement manually when you use the SQLExecutor transformer.
Why not use the Oracle writer?
  • December 29, 2016
arthy
  • December 29, 2016
@takashi,
Using the oracle writer, I don't need anymore to use the NullAttributeTranformer and the workspace runs succesfully.
However, there is an efficiency issue. The processing is multiplied by approximately 1.5 (from 18 minutes with the New Value being of the <map to^parameter set to '' to 27 minutes with the oracle writer).
Is there anything that I can to speed up the translation?
Many thanks,
  • December 30, 2016
@arthy, If you need to build a SQL statement anyway, you can map <null>, <missing>,  and <empty> for numeric type fields to constant string null using the NullAttributeValueMapper. If attributes called 'NUMERIC1' and 'NUMERIC2' should store values for nullable numeric fields in the destination database table, the parameters setting would be like this.
Then, this expression in the following SQLExecutor generates the correct SQL statement. Assume 'STRING1' and 'STRING2' are for string type fields.
insert into the_table (NUMERIC1, NUMERIC2, STRING1, STRING2)
values (@Value(NUMERIC1), @Value(NUMERIC2), '@Value(STRING1)', '@Value(STRING2)')
If all the attributes store <null> or <empty>, or those are <missing>, this statement will be generated.
values (null, null, '', '')
