MapnikRasterizer is giving an error!
  • July 15, 2016
  • 104 views
What could be the issue here. `MapnikRasterizer` is giving an error!
MapnikRasterizer(MapnikFactory): Performing rasterization...
MapnikRasterizer(MapnikFactory): Failed to rasterize data. The error was: bad allocation
MapnikRasterizer(MapnikFactory): A fatal error has occurred. Check the logfile above for details
Here is FME file:
https://drive.google.com/file/d/0BwMirpbclFbrLUF6d...
@redgeographics
  • July 16, 2016
As stated here in this article, there is a bug with MapnikRasterizer. this transformer unlike imageRasterizer gives the option to change color of line, text, polygon etc. If using MapnikRasterizer is not possible how can I customize the color of the lines and the text before imageRasterizering.
Forum|alt.badge.img+64
That would be FeatureColorSetters like you've used before. However, I would try the fixes suggested in that article on the MapnikRasterizer bug too. Probably tiling (using a Tiler) and then mosaicking afterwards would be the best solution. The MapnikRasterizer has a Group By parameter, if you set that to the _column and _row attributes coming out of the Tiler and potentially set parallel processing too it could save you memory and time.
