MAPNIK Rasterizer giving unexpected output
  • Jul 11, 2020 8:57 PM UTC
  • 64 views
boubcher
Forum|alt.badge.img+11
Hello There
running a simple workspace with Mapnik, the input is a line but I am getting box, no idea why
Best answer by fme-phile
Hi @boubcher
Check your input dataset and If in degrees, you will need to change your Cell spacing to reflect this. try changing your cell size to 0.001
fme-phile
  • Jul 12, 2020 8:02 AM UTC
Hi @boubcher
jdh
Forum|alt.badge.img+41
  • Jul 13, 2020 2:58 PM UTC
At a guess your line width of 28 pixels is completely overwhelming the geometry.
Your cell spacing is 2, what projection is your data in, and how many pixels does the line feature correspond to in the output map?
boubcher
  • Jul 14, 2020 7:17 PM UTC
Thanks Guys
