MapInfo file extensions
  • May 22, 2018 12:07 PM UTC
  • 55 views
Hi
I have a MapInfo SQL Select query which I save off as a table and I would like to do the same query as an FME workspace. When I create the MapInfo writer to save the table it save the file with the 4 filename extensions (.tab, .dat, .id and .map) whereas when I save the SQL Select query from MapInfo there are only 2 filename extensions (.tab and .dat).
What I would like to know is it possible to save the FME MapInfo file with the .tab and .dat file extensions.
Thanks
Andy
  • May 22, 2018 1:35 PM UTC
If you can use the new "MapInfo Extended" writer, it will do this for you automatically.
If not, I suspect you'll have to manually delete the unwanted files after the workspace has terminated, e.g. by using the shutdown script.
