Map List to SQL Server Table
  • Apr 25, 2018 8:02 PM UTC
  • 102 views
venkat
Participant
I am reading table name and attribute values from text file. I do not have column names but only table name and values in the list.
I would like to insert the values into SQL Server table. How do I map list to destination table schema. The order of column values match with table structure.
Following is the example of text file row.
I~6000000~PDEN ~A058951~PI~PI~DEHYDRATOR~~261384~~~B&C; COMPRESSOR STATION~802103~~~~~~~~~~~~A~~A~USA~17~027~~61~022033~~~~~~20171001~~~~~~~~N~~~~CONGRESS_PRD~~3~~~~~~~~~~~~~~~~G~LA~~L~~~~~~~~~~~~~~~~~~~~
'I' is the transaction type.
6000000 is table id
PDEN is the table name.
Rest of them are Attribute Values.
Text file can contain values for multiple tables and it can have update or deletes also.
For now I am trying to find a solution for inserts.
Please let me know your thoughts.
tim_wood
Forum|alt.badge.img+8
  • May 1, 2018 10:02 AM UTC
You can use the AttributeSplitter to split up the text on the tilde (~) character, and you can choose to "Drop Empty Parts" to deal with all those consecutive tildes. Or if consecutive tildes mean empty columns, don't "Drop Empty Parts".
Do you know the column names? If so, you can map the values to the correct columns in the AttributeManager, picking up the relevant element in the list that AttributeSplitter produces.
Tester or TestFilter can filter out just the features to insert.
You can use the table name attribute as the Fanout on the Writer to insert the record into the correct table.
I'm unclear what the table id is - is this the primary key value in the table you are writing to?
If you then want enhance the Workspace to deal with updates, you can use the I, U, D values to set the fme_db_operation value for the Writer.
venkat
Participant
  • Participant
  • May 2, 2018 7:18 PM UTC
Hi Tim, Thank you for your answer. I am trying to download textlinenone.fmw but it throws an error.
Can you please re upload the file again?
Regards,
Venkat
debbiatsafe
Forum|alt.badge.img+24
Regards,
Venkat
Hi @venkatakondepat
If you right-click on textlinenone.fmw and select 'Save Link As' (or your browser equivalent), you should be able to download the workspace. Hope this helps.
