manual attribute type definition in CSV reader (FME v2022.1)
  • Jun 6, 2023 9:39 AM UTC
  • 271 views
mzuer
Forum|alt.badge.img+5
Dear all,
I am using a CSV reader to read my data from csv file. I have a column that contains almost only integer except 5 values, that contain a letter (e.g. 12a or 12b). Unfortunately the reader set the Type of this attribute to uint32, and the values that contain a letter are set to Null... So I loose this information...
It seems that in older versions of FME there was possible to choose "Manual" for "Attribute definition" parameter. But I doesn't see this option in the 2022.1 version of FME.
How could I do then to force this column to be read as a string ?
I've seen that it is possible to specify manually attribute types in the FeatureReader, but could I use this transformer to read a file ? (I set the file path in the parameter, but I don't know what to pass in input, and the output is empty)
Thanks in advance for any help
Best answer by nielsgerrits
you can use a Creator to initiate the FeatureReader.
nielsgerrits
Forum|alt.badge.img+67
  • Jun 6, 2023 10:15 AM UTC
mzuer
  • Jun 30, 2023 7:35 AM UTC
thanks ! it is what I did finally but was curious to know if it was possible to do it with the csv reader
nielsgerrits
Cheers. I'm quite sure it can also be done in a classic CSV reader but since the FeatureReader was added I've never used a classic reader anymore, so I need to really look into it. Personally I prefer the Creator / FeatureReader over the classic reader as I find it more intuitive.
