Making polygons that look like pie
  • Nov 20, 2019 3:23 PM UTC
  • 60 views
Hello, I need help. I got input data(points) with attributes: LONGITUDE, LATITUDE, AZIMUTH, AZIMUTH RADIUS AND AZIMUTH WIDTH. I need to get output polygons that look like a pie.
Best answer by redgeographics
I think this would do the trick:
Although I haven't looked at what happens if the pie slice crosses the 0 degrees line.
piebaker.fmw
Forum|alt.badge.img+63
piebaker.fmw
Forum|alt.badge.img+54
  • Nov 20, 2019 4:17 PM UTC
piebaker.fmw
The 2DArcReplacer considers the angle counter clockwise from the horizontal. Not the azimuth
  • Nov 20, 2019 5:46 PM UTC
piebaker.fmw
Thanks, you helped me a lot.
  • Nov 20, 2019 5:49 PM UTC
It is correct. But in the formula, we can add : if 450-(azimuth-(width/2)) >360 then (azimuth-(width/2)) -360 else if 450-(azimuth-(width/2)) <360 then (azimuth-(width/2))
