Making black No Data cells transparent in ECW raster mosaic
  • March 29, 2017
  • 6 replies
  • 306 views
I am creating an ECW raster mosaic from around 500 JPGs using the RasterMosaicker transformer, in FME 2015.1. The attached snapshot shows a test piece of the resulting mosaic, but ideally I would like the areas with no data to be transparent, not black. Is this possible? I have read some threads on a similar theme but I find the answers where bands are discussed difficult to understand as I don't have enough knowledge in this area. Is there a simple solution? Probably not! Many thanks.
zzupljanin
Forum|alt.badge.img+5
  • March 29, 2017
Have you tried RasterInterpretationCoercer. Convert from RGB to RGBA and select to 'create alphaband from no data'. If black pixels aren't defined as nodata use RasterBandNodataSetter before RICoercer.
Cheers,
Želimir
  • March 29, 2017
OK many thanks, @zzupljanin - I'll try and experiment with this.
helmoet
Forum|alt.badge.img+8
  • March 29, 2017
rastertransparancy.fmw I experimented with this, see attachment. Might also be a good tip to add transparance before mosaicking to avoid black backgrounds, see
https://knowledge.safe.com/articles/18764/setting-alpha-vs-nodata-color-and-numeric-data.html
Hope this inspires you @masoj1.
  • March 29, 2017
Wow thanks, @helmoet , I'll try this too as soon as I can.
kampinga_c
Participant
  • Participant
  • June 26, 2019
@helmoet, is there a way, i can get the attachment 'rastertransparancy.fmw'? The attechment in your reply doesn't work anymore.
helmoet
  • June 28, 2019
@kampinga_c here it is again, though it is a bit of an oldy...rastertransparancy.fmw
