Make list "ID" of touching building footprints within an area.
  • Nov 18, 2019 3:27 PM UTC
  • 8 replies
  • 117 views
kidega
Forum|alt.badge.img+9
Hello,
I am trying to find a soultion of workflow in FME, as to the attached image.
My first attempt was to use the "NeighborFinder" and check if a footprint touches another. Then group/ list those (light blue circle). Then perhaps do another "NeighborFinder" check within a i.e. distance of 15, and make that a merged list (dark blue circle).
I appreciate any idéas. Thank you!
Best answer by ebygomm
There is a custom transformer on the hub - ListCombiner - that may help you to create your groups once you have lists.
So if you use a spatial relator and send your buildings in as both requestor and supplier and build a list of related ids, you can then use list combiner which would assign the same group id to all buildings that touch
jdh
Forum|alt.badge.img+41
  • Nov 18, 2019 4:50 PM UTC
I've done something similar where I've used the SpatialRelator (Intersects) and then a pythonCaller to do a connected component analysis of the resulting lists, and assign the resulting group id to each feature.
Avoiding Python, you could use a dissolver (Drop Incoming Attributes_, counter (to get a unique id per group) and then a spatialFilter (Merge Attributes) with the dissolved features as filters and original features as candidates.
A bufferer before the dissolver would give you the dark blue result.
kidega
  • Nov 20, 2019 6:53 PM UTC
Hello @jdh
Thanks alot for trying to point me to the right direction. I am not familiar with python so I will try your suggestion with the disslover, spatialFilter and bufferer.
Forum|alt.badge.img+54
  • Nov 20, 2019 7:05 PM UTC
jdh
  • Nov 20, 2019 8:02 PM UTC
Why am I not surprised that @takashi has a custom transformer that does exactly what's needed.
This is a generalized case of the connected component analysis I mentioned in my answer.
kidega
  • Nov 20, 2019 10:53 PM UTC
Thanks alot @ebygomm ! This looks exactly what I am after. Do you think adding a bufferer @jdh was talkiing about would determine No. of group id:s?
kidega
  • Dec 10, 2019 12:43 PM UTC
Hello, I wounder what type of parameter settings you used in the SpatialRelator and ListCombiner transformers to get the sorted _group_id:s?
fmelizard
Forum|alt.badge.img+22
  • Dec 11, 2019 7:29 PM UTC
Hi @kidega I created a unique ID on every input feature with a Counter, then used the Spatial Predicates "Requestor Intersects Supplier" and "Requestor Touches Supplier" in the SpatialRelator, and in the ListCombiner I set the Source List to that unique ID from the list.
kidega
  • Dec 11, 2019 9:16 PM UTC
Hi @danatsafe Thanks for explaining, now I got it working!
