Looping a list to clip features
  • Apr 11, 2025 3:18 AM UTC
  • 157 views
koala_pond_03
Participant
Hi everyone, can you please help me out with this one? I have a vector layer with canopy heights. For example:
name, index
0-1m, 0
1-2m, 1
2-3m, 2
3-4m, 3
4-5m, 4
As the features had been captured by LiDAR, they overlap each other. I am trying to clip the features to show max canopy heights, if that makes sense. 0-1m will be clipped by canopy heights >1m, 1-2m will be clipped by canopy heights >2m, 2-3m will be clipped by canopy heights >3m, etc.
I don't understand how to set up a loop in a way that can filter and dissolve higher canopy heights. All feedback and suggestions are appreciated.
hkingsbury
Forum|alt.badge.img+73
  • Apr 11, 2025 8:11 AM UTC
You won’t need to loop. you should be able to use the PointCloudExpressionEvaluator to build an expression that sets a component on the pc to the appropriate index
https://docs.safe.com/fme/2024.2/html/FME-Form-Documentation/FME-Transformers/Transformers/pointcloudexpressionevaluator.htm
even something as simple as getting the floor of the z value should give you what you need.
floor(0.7) = 0
floor(9.32) = 9
floor (10.01) = 10
  • Apr 11, 2025 8:56 AM UTC
Hi ​@koala_pond_03 ,
I assume that you have polygon features with an attribute called e.g. “canopy_height” that stores the canopy height value, and you want to remove area overlapping with other higher canopy polygons from every polygon.
If I understand requirement correctly, AreaOnAreaOverlayer and list operations could be a simple solution.
  1. Send all the canopy polygon features into an AreaOnAreaOverlayer.
    • Accumulation Mode: Drop Incoming Attributes
    • Generate List: [check]
    • List Name: _list (for example)
    • Add to List: All Attributes
  2. ListSorter: Sort the list elements by canopy height desecnding.
    • List Attribute: _list{}.canopy_height
    • Sort Type: Numeric
    • Sort Order: Descending
  3. ListIndexer: Extract the first elements of the list as feature attributes.
    • List Index to Copy: 0
Hope this helps.
koala_pond_03
Participant
  • Participant
  • Apr 17, 2025 12:49 AM UTC
Many thanks to ​@hkingsbury and ​@takashi for the help. I’ll look into these ideas this week. Cheers!
