looking for a way to unpack a file from .tar and 'gz' archive
  • Jun 12, 2018 6:45 PM UTC
  • 235 views
i am able to download a .TAR file, which contains a .GZ file, which in turn contains multiple .grb2 file (with no extension). i am needing to get these files into a directory and add in the ".grb" extension.
  • Jun 13, 2018 12:57 AM UTC
Hi @dlindner01, FME itself doesn't have a functionality to unpack tar/gz archives. However, if you install 7-Zip into your machine (assuming that your platform is Windows), you can unpack them using that through the SystemCaller transformer.
See also this relevant Q&A;: Can I read shape files dat are gzipped (.gz)?
  • Jun 14, 2018 8:54 PM UTC
Great, Thank you! i will investigate and hopefully this is what i am looking for.
