Look behind regex in StringSearcher
I'm trying to use the following regular expression in StringSearcher (?<=Switch Description ).{5} So for example applied to the following text "Switch Description 1757A" it would find "1757A" However, im getting the following message "couldn't compile regular expression pattern: quantifier operand invalid" Anyone know why this is?
