Look behind regex in StringSearcher
  • November 9, 2015
  • 78 views
I'm trying to use the following regular expression in StringSearcher (?<=Switch Description ).{5} So for example applied to the following text "Switch Description 1757A" it would find "1757A" However, im getting the following message "couldn't compile regular expression pattern: quantifier operand invalid" Anyone know why this is?
  • November 10, 2015
Some modules of FME including the StringSearcher use Tcl to perform regex operations internally, and Tcl regex engine seems to be one which doesn't support lookbehind unfortunately. See also here.
Takashi
Thanks Takashi. I guess i'll have to find the whole string then split it.
  • November 10, 2015
Yup, if you need to split a text starting with "Switch Description" into the description text and the last 5 characters, this regex would work for the StringSearcher, for example.
(Switch Description)\s*(.{5})
fmelizard
Forum|alt.badge.img+22
  • November 13, 2015
I can also advise that in FME 2016, all regular expression evaluation is now unified under a new, modern, non-Tcl engine.
