Logging to a log file -new line problem
  • Aug 16, 2019 4:02 AM UTC
  • 60 views
I use the below items
* Use an attributeFileWriter
* Use a dynamic string built up eg -----------------------------------2019-08-14 15:18->Roads in gdb:37574----------------------------------------------------------------------2019-08-14 15:18->Roads in gdb with duplicate removed:37572----------------------------------------------------------------------2019-08-14 15:18->Roads in SDE::37474----------------------------------------------------------------------2019-08-14 15:18->Roads in SDE with duplicate removed:37454-----------------------------------
* I log into a txt file
* After every ----------------------------------- I have a new line inserted
Problem-
* When I open the text file, why don't I see the line feeds as I inserted them
Cofusion-
* when I copy/paste the contend into a rich editor eg browser, Word I can see the line feeds
Forum|alt.badge.img+63
It may depend on encoding, your operating system and which text editor you use to check it.
What works for me (on a Mac) is using an AttributeManager to add a newline at the end of the attribute before writing it to the log file with the AttributeFileWriter.
  • Aug 19, 2019 4:55 AM UTC
I get it correctly in "Notepad++" but not in "Notepad"
I believe the answer is in the encoding, "System.default" is what I set
