logging FME Server job status at begin and end to Oracle Non spatial table
  • February 6, 2018
  • 31 views
annette2
Forum|alt.badge.img+11
I have written an FME workbench hosted on FME Server that will be called by the Informatica application.
The Informatica team want a logging mechanism via an Oracle non spatial table.
The columns in the table are
workbench_id (published parameter filled by Informatica job call)
workbench_name (fixed value - e.g Clipper_Perf_POC)
run status (1 = run started, 2 = run success, 3 = run failed)
They want to insert a log message at the start and a second log message at the end of a workbench..
What is the most elegant way to do this - start up and shutdown scripts, fmeserverjobsubmitter (aka workspace runner)? Is it worth adding the fme server job id to the table...the workbench_id parameter filled by Informatica is not very informative for further investigation within FME Server.
Any tips would be appreciated.
Best answer by takashi
Hi @annette2, I would adopt an approach using the FMEServerJobSubmitter.
To the first workspace, add a process to insert the Job ID (and "workbench_id" if necessary) and the "run started" status to the logging table at first.
Then, create another workspace which contains a FMEServerJobSubmitter (Wait for Job Complete: Yes) to run the first workspace. To the second workspace, add a process to update the status of the record to "run success" or "run failed" according to result of the translation run by the FMEServerJobSubmitter.
I'm not sure whether it's elegant but I think the implementation is easier and also the maintainability is better than using Startup/Shutdown Python Script, in most cases.
  • February 6, 2018
annette2
  • February 12, 2018
Many thanks Takashi. I am going to try this out this week
