There is no log file written to the set output folder (as a parameter) when running the workspace from FME Server. The FME server version is FME(R) 2019.2.3.2 (20200320 - Build 19825 - WIN32). What could be the reason?
- Home
- Forums
- FME Form
- Transformers
- Log file not written
- Jul 20, 2020 10:04 AM UTC
- 16 replies
- 268 views
- Jul 20, 2020 10:30 AM UTC
It seems that FME Server overrides the workspace log and redirects it as the server job log, so that your published parameter isn't taken into account.
A possible workaround could be to copy the job log in the shutdown script, e.g.
import fme
import shutil
shutil.copyfile(fme.logFileName, fme.macroValues['TARGET_LOGFILE'])Expects a published parameter TARGET_LOGFILE containing the folder or filename of the log copy.
- Author
- Contributor
- Jul 20, 2020 1:00 PM UTC
import fme
import shutil
So it is a bug?
- Author
- Contributor
- Jul 20, 2020 1:02 PM UTC
import fme
import shutil
How do I copy the job log in the shutdown script? Where,...
- Jul 20, 2020 1:29 PM UTC
Seasons greetings, FMEers.
Our main question this week comes from our support queue and relates to published parameters used programmatically.
Note: I have an up-to-date list of previous Question of the Week topics in case it's of interest to you.
Question of the WeekQ) The behavior of choice with alias parameters on FME Server does not seem to be working as expected when called programmatically. Values are taken literally and not converted. Can you please confirm how it should work?
A) Of course. It might seem odd, but I believe this is actually working as designed. The difference is in running a workspace through FME (Desktop or Server) and running it programmatically. Let's see why...
Choice with Alias ParametersHere's a quick refresher on user parameters in general and the Choice with Alias type in particular.
A User Parameter is a way to get input from a user when they run a workspace. They are sometimes also called Published Parameters, since you publish them to get user input, or keep them private for your own use.
User parameters come in many styles, for different types of input. A Choice with Alias type of parameter is where we present the user with a list of options, but return a different value to FME. Let's look at an example. Here our accounting department has a Choice with Alias:
Later there is an SQLExecutor transformer that gives the chosen user a 50% pay rise:
UPDATE employees SET salary = salary * 1.5 where employeeID = "$(Employee)"If I run this in FME Desktop (left) or FME Server (right), it looks like this:
The important part is that the user gets to select an employee name, but the value passed to the SQL statement is the employee ID number, which is what the database expects.
But what if I run this programmatically?
Running a Workspace ProgrammaticallyWhat do I mean by programmatically? Well, I mean, not using an FME user interface. For example, when I do run it in Workbench I'm told what the command would be to run this in a script:
Using that command in a bat file (for example) would mean running the workspace programmatically.
Be sure to notice that the user parameter value it suggests you submit with the workspace has already had its alias replaced with the true value.
Let's see if the same is true in Server:
Yes, when I create a webhook to run the workspace the same substitution has already taken place.
In short, it's not the FME engine that carries out the switch, but the tool that initiates it.
Or at least, that's what it seems to me. So when I create a tool for running a workspace programmatically, it's expected that I'm responsible for presenting published parameters to the user, including any aliases I might care to apply.
Why is this the expected method? Well, I haven't checked with our developers so I can only guess. But the whole Choice with Alias parameter comes about because we want to be able to show a complex string to the user but deliver a simple string to the FME engine.
For example, if I were creating a parameter to let the user decide on the choice of a coordinate system:
...would I really want to pass a value like "Ontario MTM Zone 12,82.5-79.5W over47N, 82.5-80.25W toS; NAD83 [EPSG #32192]" though a URL or command line?
But, as a developer, is there any way I can make use of these aliases programmatically?
Listing and Validating ValuesWe now know that the FME engine won't substitute an alias for our choice and (presumably) validation of other parameters is done the same way. For example, if a Number parameter is defined in a workspace, validation that the input is actually a number (not text) must also be done by the interface, not the engine.
So if I'm creating a web-based solution to run a workspace, maybe I'm not the same person as the workspace author. Maybe I know the parameter name but I have no idea what sort of input is permitted. Or perhaps the workspace was edited without me even knowing about it!
Is there a way to query FME to find out what values I should present to the user?
Why, yes! The REST API repositories method:
Now I know. I make the call and in return get a formatted list of permitted parameter values.
But what happens if I mess up and pass through the choice instead of the alias (or another non-conforming value)? Then the value will be used literally. In my example the SQLExecutor will try to run:
UPDATE employees SET salary = salary * 1.5 where employeeID = "Mark Ireland"So what would happen there?
If the employee ID was purely numeric, then a text value would probably cause the SQL itself to fail. If the employee ID was text then the SQL will run but return zero records.
Hopefully there would be some other test in the workspace to error trap such a case - otherwise I won't be getting my salary increase!
Note: This is why I always emphasize the need to trap potential errors in a workspace. You might think that everything is all under control, but only error trapping assures that. Test your inputs and connect those Rejected ports to something, folks!
So there we go. That's how a Choice with Alias parameter works when running a workspace programmatically. I hadn't thought about it until the question was raised, but it is logical.
The key is that FME engines don't validate user input. User input should be validated by the program submitting the request.
If you want to know more about how to dynamically generate a form showing user parameters, check out this section of the FME Server API training course.
Other Notable QuestionsSome other notable questions this week are...
- When and how to use Attribute Management Transformers for Performance Tuning
- @bwn asks this question and it is interesting to wonder if the time taken to remove attributes exceeds the time gained in performance. But what is most interesting is when @markatsafe (as opposed to me, @mark2atsafe) reports how the AttributeKeeper is not bulk-mode compliant (yet) and so can impact performance.
- Time Conversion from Local to UTC (and Vice Versa)
- Not so much a question as a tip from @egge - the @TimeZoneSet function is very handy and doesn't have an equivalent transformer, so it's not as well known.
- Incidentally, all users, please feel free to post tips like this to the forums. I know they are very much appreciated by all.
- Comparing Dates in FME
- A good question from @muhammad_yasir about how to compare dates in the Tester. What's particularly interesting is that the dates appear to be YYYYmm only, and exclude the day. But beyond that, it's a reminder to always set the comparison mode to Date/Time in the Tester when necessary.
- Calculating Multiple Attributes using the ExpressionEvalautor
- Another good question from @muhammad_yasir. The point to note is that if you have a bunch of different calculations to carry out, then the ExpressionEvalautor is not the transformer to use. Use an AttributeManager, AttributeCreator, or similar.
- On the other hand, if you have a bunch of attributes that need the same calculation carried out, then the ExpressionEvalautor is the one to use. You replace the attribute name with @CurrentAttribute() in the expression, and FME works through each attribute one at a time.
- Turning Off Feature Caching for a Workspace
- We know how to turn off feature caching, but does the end-user, asks @virtualcitymatt. It's a good point. Currently, we would say to use the Quick Translator, but perhaps the ideas linked to in the question will help?
- Jul 20, 2020 1:34 PM UTC
Just copy the code I wrote above into the workspace Python shutdown script. Also either make sure you have a published parameter called TARGET_LOGFILE or modify that string in the code to use the published parameter your prefer.
- Author
- Contributor
- Jul 21, 2020 7:31 AM UTC
import fme
import shutil
Unfortunately this does not seem to work. There is still no log file written to the desired location nor is it written to the location that the FME Server Log file points out: --TARGET_LOGFILE' `D:\ProgramData\Safe Software\FME Server\repositories\XXX\YYY/Logs (XXX being my repository and YYY being my workspace). That "/Logs" folder does not exist. I could find the log files in D:\ProgramData\Safe Software\FME Server\resources\logs\engine\current\jobs\2000 by their job submission id, but how long will they be stored? And their names are not convenient.
- Jul 21, 2020 8:12 AM UTC
Unfortunately this does not seem to work. There is still no log file written to the desired location nor is it written to the location that the FME Server Log file points out: --TARGET_LOGFILE' `D:\\ProgramData\\Safe Software\\FME Server\\repositories\\XXX\\YYY/Logs (XXX being my repository and YYY being my workspace). That "/Logs" folder does not exist. I could find the log files in D:\\ProgramData\\Safe Software\\FME Server\\resources\\logs\\engine\\current\\jobs\\2000 by their job submission id, but how long will they be stored? And their names are not convenient.
Out of curiosity, what are you trying to accomplish by copying the log files out of FME Server? I've never seen that use case before.
- Author
- Contributor
- Jul 21, 2020 10:34 AM UTC
Basically the same thing as done before using Desktop; viewing the log files directly using windows explorer and an text editor. In FME Server the log files tend to get lost in the mass, since they don't have the names of the output in the log file names (All completed looks the same in the completed list if run by the same workspace but using different parameters (in my case hundreds of them).
- Jul 24, 2020 11:09 PM UTC
Can you try not writing it to the FME Server repository? If you're determined to keep it within the FME Server system share, please try the Data folder which is intended for user interaction. Or use a completely different folder on your system that the account running the engine service can access.
I would suggest looking to see if your python script is running correctly - you can check this in the engine process monitor log if there are any warnings or if you want to try printing the destination path to confirm the locations are where you expect.
- Jul 24, 2020 11:16 PM UTC
Are you regularly needing to check in different job log files?
The FME Server REST API might be a more elegant solution depending on your needs. You will be able to return completed jobs (success/fail) and the response includes the published parameters and their values: https://demos-safe-software.fmecloud.com/fmerest/apidoc/v3/#!/transformations/listCompleted_get_13
- Jul 27, 2020 8:49 AM UTC
The folder specified in TARGET_FOLDER needs to already exist, otherwise the Python shutdown script will fail. Alternatively, you can add the following to the shutdown script to create the folder, if necessary (Python 3.4+):
import os
os.makedirs(fme.macroValues['TARGET_LOGFILE'], exist_ok=True)Also, I agree with @jlutherthomas about not writing log files to the server repositories.
- Author
- Contributor
- Jul 28, 2020 11:43 AM UTC
Yes I have not tried to write it to the FME Server repository. My destination is set on a separate folder on the D: drive. Still it does not work. The log file for some reason prints "D:\\ProgramData\\Safe Software\\FME Server\\repositories\\XXX\\YYY/Logs" which is not where I have set it.
- Author
- Contributor
- Jul 28, 2020 11:49 AM UTC
Thank's this would probably be a good option!
- Mar 10, 2022 11:47 PM UTC
I'm having a similar issue. I have a complex workbench in which I have two workspace runner. These two runners work perfectly fine if they are used as direct workbench or if I use them with a creator in a very simplified workbench. In the real main workbench, although everything runs without raising any error, the runners produced no outputs and there are no log files generated for either runner. I have tried several work around (including the suggestion above and forcing the log file name in the logging parameters) but nothing works. Without those log files, it is difficult to find out what the real problem is....
Community Stats
- 33,005
- Posts
- 125,089
- Replies
- 41,951
- Members
