Local bearing along a line
  • Dec 8, 2015 11:16 PM UTC
  • 12 replies
  • 726 views
jdh
Forum|alt.badge.img+41
Suggestions for an efficient way to determine the local bearing of an arbitrary location along a line. Local bearing is the azimuth angle of a given point to the next vertex in the line.
Bonus points if it iterates easily.
Best answer by gio
Like this?
1. Use chopper on polyline.
2. extract start and end vertices, and name them accordingly. I used S_x,S_y\\
and E_x,E_y.
3. calculate angle.
4. vertexcereator replace mode for startpoints.
5. vertexcreator with following vlaues
x= @Value(S_x)+@Evaluate(@Value(OFFSET)*@cos((@Value(Hoek_)/180)*$(Pi)))
y= @Value(S_y)+@Evaluate(@Value(OFFSET)*@sin((@Value(Hoek_)/180)*$(Pi)))
Offset variable i created to give lenght to a "bearingpointer" (arrow/vector)
Set lenght to you desire.
Now u got your bearing.
(nb. if you use Azimuthcalculator you wont need to extracxt endcoordinates.)
roland.martin
Forum|alt.badge.img+11
If I've understood correctly, you want to split the line into 2-vertex segments (Splitter set at 2 vertices) and then use this custom transformer to get the angle. If you wish to assign the result back to the first point in each line segment, use a CoordinateExtractor to extract vertex 0, followed by a VertexCreator replacing the line with a point.
r.
gio
Forum|alt.badge.img+15
  • Dec 9, 2015 11:23 AM UTC
Like this?
and E_x,E_y.
3. calculate angle.
jdh
  • Dec 9, 2015 3:16 PM UTC
r.
I don't want the bearing at every vertex, but rather at specific points along the line, which may or may not correspond to an existing vertex.
jdh
  • Dec 9, 2015 3:23 PM UTC
Like this?
and E_x,E_y.
3. calculate angle.
This gives me some ideas for a starting place. Thanks.
roland.martin
Sorry, I missed that.
OK, start by splitting the line at the points - there are various transformers that do this, but the simplest is probably PointOnLineOverlayer. So:
  1. Add a counter to your points, so you have a unique ID
  2. PointOnLineOverlayer
  3. AzimuthCalculator
  4. FeatureMerger, to join your lines with azimuth back to the original points, based on the unique ID
I also meant Chopper rather than Splitter, but that's academic now...
  • Sep 8, 2018 6:32 AM UTC
Hi @gio Would you be able to share your fmw Workspace for this solution please?
  • Sep 8, 2018 6:34 AM UTC
Hi @gio , Would you be able to share your fmw Workspace for your solution please?
gio
  • Sep 10, 2018 8:58 AM UTC
@johnm
Hi, sure.
It's still on my machine.
The arrow custom is more complex then the main though...linebearings.fmw
Have fun.
  • Sep 10, 2018 10:17 AM UTC
Hi @gio, Thanks for this, I would like you to have a look at the one I did to see what you think?
Will get back to you tomorrow with the fmw.
gio
  • Sep 10, 2018 10:32 AM UTC
Sure, my pleasure.
  • Sep 11, 2018 10:29 AM UTC
Hi @gio, Here is another script (2016) for the arrow where the direction angle is provided. Cheers.
createarrow.fmw
gio
  • Sep 11, 2018 11:53 AM UTC
createarrow.fmw
Hi @johnm
Tx.
My arrow creator is scaled by input (larger line => larger arrows. Also size of arrowhead, shaft etc. are variable.)
It takes input lines, points or just attributes.
I have tried to make it as flexible as possible. It has evolved a bit since I posted above script. Trying to get it to make all kinds of arrowheads.
The createarrow.fmw is fixed size and has hardcoded values.
