ListCombiner, no attribute
  • Dec 14, 2019 12:49 PM UTC
  • 95 views
kidega
Forum|alt.badge.img+9
Hello @takashi I have an AreaBuilder before the ListCombiner. If areas are built they are then checked if they touch/ intersect via SpatialRealtor. After that the ListCombiner will group on the spatial settings.
The problem is that if no areas are built (incomplete), I get the error message "PythonFactory failed to close properly". Is that probably because there is no attribute from built area to compute on in "orderByGroup"?
So I wounder if there is a way to not activate ListCombiner (PythonCaller) if AreaBuilder returns incomplete?
Please see attached image for log message.
Thanks.
Best answer by takashi
Hi @kidega, thanks for letting me know that.
You are right. The ListCombiner will raise the error if no features have been input into the transformer.
You can avoid the error by editing the Python script. Try this:
  1. Right-click on the transformer GUI > Edit to open the Canvas for the transformer definition.
  2. Open the PythonCaller parameters dialog and add a line to the __init__ definition like this.
class ListCombiner(object):
    def __init__(self):
        # "snowballs" dictioinaly
        # key: value of a list element
        # value: tuple (set of features belonging to a group, set of combined list elements of the group)
        self.snowballs = {}
        self.features = [] # features list keeping the input order.
        self.kAttrIndex = '__listcombiner.index'
        self.orderByGroup = False ###### Add this line to avoid the error #####
  • Dec 14, 2019 1:49 PM UTC
    def __init__(self):
        self.snowballs = {}
kidega
  • Dec 14, 2019 2:05 PM UTC
    def __init__(self):
        self.snowballs = {}
Hi @takashi Thanks, that worked like a charm!  And thanks for quick reply.
  • Dec 14, 2019 2:12 PM UTC
    def __init__(self):
        self.snowballs = {}
You are welcome. I updated the transformer in FME Hub too.
https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/listcombiner
kidega
  • Dec 14, 2019 2:27 PM UTC
    def __init__(self):
        self.snowballs = {}
Okej that's great.
