List Attribute Issue
  • Apr 27, 2018 9:25 AM UTC
  • 6 replies
  • 115 views
I have the following list attributes set up in an AttributeManager which I am passing to an Excel Spreadsheet Writer set up in Dynamic Schema mode.
The first attribute named 'TEST' is outputting correctly in the Excel Spreadsheet with the values from the field named 'LIST_0' (which is not actually a list, just to confuse) populating the column as expected.
In regards to the second attribute, which I have named dynamically from an actual list called 'LIST_NAME_UNIQUE{}', the column name in excel is outputting the correct name as per the list value I specified, but no values are populating the column.
Can anyone see what I'm doing wrong here? I feel like it is a really simple mistake but I just can't work it out...
I am using FME Desktop 2017.1.1.1
Thanks,
  • Apr 27, 2018 10:00 AM UTC
Hi @aquamarine, a list attribute can store multiple values as its elements, but a column in a spreadsheet can contain only a single value. I don't think that the values stored in a list can be written into a column, even though the dynamic schema creates a field name corresponding to the list.
If the list contains two or more values, what value should be written into the destination column?
  • Apr 27, 2018 10:04 AM UTC
Hi @takashi the actual values are in an attribute called 'LIST_1' but they are not actually a list, I just named it that unfortunately. The thing that is confusing is that the column I named 'TEST' does get populated with the values in the attribute called 'LIST_0' but for the column which I named dynamically, this is not happening...
  • Apr 27, 2018 10:32 AM UTC
If you are going to assign the value of "LIST_1" to "LIST_NAME_UNIQUE{1}" and then use it as a destination attribute name, the assignment should be before create the corresponding schema definition - i.e. "attribute{1}.name".
  • Apr 27, 2018 10:37 AM UTC
You can see the difference between TEST and LIST_NAME UNIQUE{1} with the Text Editor.
TEST
@Value(LIST_NAME_UNIQUE{1})
  • Apr 27, 2018 12:01 PM UTC
TEST
I have tried swapping the order (see image below), but it hasn't seemed to make any difference.  Have I misinterpreted what you mean?
Note: I've renamed the attribute 'LIST_X' to 'ATTR_X' to reduce any confusion.
  • Apr 27, 2018 12:31 PM UTC
TEST
Oh I finally got it:
I had to be careful to ensure the  had a capital 'V' otherwise it didn't work.
