Lines and points connection
  • Dec 26, 2017 12:15 PM UTC
  • 21 replies
  • 155 views
Hello,
I am trying to join parcel number to parcel in FME. I am importing geodetic plan in .DWG but I decomposed it in layers in .SHP to manipulate it easily.
I am facing a few problems. My plan is consisted of few layers. All parcels are made of lines and points and first thing I need to do is to make polygons(area) of these lines and points but LineBuilder and LineCloser are not helping me. I also tried with NeighborFinder but that doesn't work for me neither.
What transformer could I use to make area because after that I know how to join attributes (parcel number) to an area.
Thank You in advance,
MaliodPalube
Best answer by pratap
Kindly find the modified workbench
polygons-close-working.fmw
pratap
Forum|alt.badge.img+12
  • Dec 26, 2017 1:24 PM UTC
It is better, if you provide some sample data to verify and suggest best approach
zzupljanin
Forum|alt.badge.img+5
  • Dec 27, 2017 9:08 AM UTC
creating parcels from lines has one important condition. Lines must be connectable so that they can form areas. Snapper, Intersector, TopologyBuilder and other transformers are necesarry to clean linear data to form areas.
Then LineBuilder, AreaBuilder and other could create good parcels...
Thank You for an answer!
I've tried with TopologyBuilder and after that I used some transformators and I am waiting for a result!
Here are two screenshots, one is Model and second is how my .DWG looks.
pratap
  • Dec 27, 2017 11:51 AM UTC
Based on the screenshot, I understand that it is possible to build polygons for parcels.
Without data, @zzupljanin suggestion holds good.
Pratap
Pratap
As You can see on screenshot, I tried with TopologyBuilder and later I used NeighborFinder and then VertexCreator. I am waiting for results right now but I will see if it will work.
Also, I think NeighborFinder should work for joining parcel numbers as atributes to final result.
Also, I am facing this problem:
This is happening for a long period of time. for almost 24h it is not moving from 99.69% and it just says that my system has no enough memory but only FME is active and I have 8gb of RAM.
He can't finish TopologyBuilder.
pratap
  • Dec 27, 2017 1:09 PM UTC
24 hours is too much of time... How many features do you have ???
Kindly provide sample data to review and suggest
Here you can see how many are there. I now started the same model on my desktop computer that is 32gb RAM so I will see what is happening. But I don't get it why it doesn't want to finish it. It is not even saying that there is mistake, only appears the same message all the time, over and over again!
zzupljanin
  • Dec 27, 2017 1:39 PM UTC
It seems that run with full inspection is on. That is really heavy for your pc. Also, when designing your workbench I suggest to run on smaller set of data, just to see if it works.
As @pratap said... If you'd provide us some sample data we could point you in more specific direction to a solution.
shp31.zip
Here is some dataset that I am working with. I would publish more but there is 1mb limit.
Tested 1219 input feature(s), wrote 1219 output feature(s): 1219 matched merge filters, 1219 were routed to output, 0 could not be routed.
pratap
  • Dec 28, 2017 3:30 AM UTC
Attached zip file contains only shp files which we cannot open either in AutoCAD or ESRI.
Pratap
Pratap
shp2812171.zip
shp2812170.zip
shp281217.zip
Sorry I forgot to upload more files.
pratap
  • Dec 28, 2017 8:00 AM UTC
shp2812171.zip
shp2812170.zip
shp281217.zip
I have reviewed the data. Most of the data is incomplete / not closed.
Does that mean you don't have data for these un-closed areas???
If you have then please export data at some location (as entire data is not required for me to work on :) )
(In question you have mentioned that input is in dwg format. It is better if you provide part from that file instead of extracted shape file).
doc1.pdf
doc1.pdf
example.dwg
Here is DWG of one small part.
pratap
  • Dec 28, 2017 9:27 AM UTC
One file is mostly completed and attached (GRALIN-3_line.shp).
I will look after after sometime for the remaining
inc.zip
inc.zip
When I run Your model I don't get expected results. I don't have an idea what could be the problem.
pratap
  • Dec 28, 2017 10:05 AM UTC
inc.zip
Please pass only GRALIN-3_line.shp file
I have tried only that file but result is this from screen shot!
pratap
  • Dec 28, 2017 11:35 AM UTC
I have placed the input and workbench in the attached for your reference as well as I have attached the screenshot of execution at my end.
polygon-close.zip
thread is going so long so kindly share your email ID
polygon-close.zip
dejandoc@gmail.com is my email and thank You a lot!
And I have tried again and I again have the same problem, it doesn't give me the output that You got.
pratap
  • Dec 28, 2017 1:45 PM UTC
