LineCombiner : Combine on Attributes parameter
  • Jan 3, 2019 1:24 PM UTC
  • 92 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have please a question about the "CombineOnAttribute" parameter for LineCombiner (FME 2019 Beta)
Is the logical relation between selected attributes to combine on is "AND" or "OR". In other words, 2 lines will be combined if they have same values for all selected attributes together or at least one common attribute ?
Thank you very much.
Best answer by itsmatt
I think it's an AND - it's instead of the GroupBy which behaved as an AND.
- So if using Nation, State, and County it should give expected results even when there are Countys with the same names in different states.
itsmatt
Forum|alt.badge.img+48
  • Jan 3, 2019 2:18 PM UTC
mark2atsafe
Forum|alt.badge.img+59
Yes, I'm 99.9% certain it's an AND (all selected attributes must match).
fmelizard
Forum|alt.badge.img+22
  • Jan 7, 2019 2:19 AM UTC
I can up Mark's by 0.1% and take it all the way to 100% -- its AND
