linebuilder doesnt connect all points
  • Mar 16, 2020 10:23 AM UTC
  • 57 views
Hello,
I try to connect points to assess certain river characteristics. I used LineBuilder > connection break attributes (to the attricube that speficies one specific profile along river). However, it's not one, line but split up in several parts, even though the attributes do have exactly the same number.
What is the reason for these 'cuts'? And moreover, how can I connect the lines?
Thank you very much!
  • Mar 16, 2020 3:46 PM UTC
Hi @ymor_v,
the LineBuilder in FME 2018 and earlier connects point features belonging to the same group only while they are entered consecutively. That is, the connection will be broken when a feature belonging to different group is entered regardless of whether the features belonging to the first group are remained.
A possible workaround is, insert a Counter to add a sequential number representing the original order, use a Sorter to sort them by the connection break attribute (primary) and the original order (secondary), and then enter them into the LineBuilder.
In FME 2019+, the LineBuilder has the Group By parameter instead of the Connection Break Attribute parameter, and you don't need to sort the source features even if the features belonging to the same group aren't entered consecutively.
  • Mar 16, 2020 5:50 PM UTC
Hi @ymor_v,
Thank you @takashi !
