line order on clockwise orientation
  • Dec 11, 2019 4:16 PM UTC
  • 5 replies
  • 111 views
alc33
Forum|alt.badge.img+14
Hi!
I have lines connected to a feature. I would like to give a number to my lines on clockwise orientation in relation to this feature.
Do you have an idea?
Thanks!
  • Dec 11, 2019 7:54 PM UTC
I'm probably oversimplifying this but anyway. :-)
1. Calculate the angle of the lines.
2. Use a Sorter to sort on angle.
3. Use a Counter to give the lines their number.
bwn
Forum|alt.badge.img+26
  • Dec 11, 2019 11:30 PM UTC
Agree, only extra thing that will help is use custom hub transformer HorizontalAngleCalculator to get an angle attribute for Step 1
  • Dec 11, 2019 11:39 PM UTC
It might be hard to define the order generally unless you add some conditions. For example, how do you define the order of the lines in this case?
  • Dec 12, 2019 8:07 AM UTC
I'll answer that question at midnight. Is that 0.00 AM or 12.00 PM by the way..? ;-)
jdh
Forum|alt.badge.img+41
  • Dec 12, 2019 9:52 PM UTC
It may be overkill, but I tend to use the TopologyBuilder, the nodeAngle list gives the lines in order from the positive x axis.
