Line direction setter
  • Jun 24, 2020 9:10 AM UTC
  • 165 views
Hello!
I have a line where the first and last vertex contains the real z height (see on photo).
I want to set the direction of the line in the that it shows to the lower point, so the 0 vertext is higher, than the last coordinate. Is there a way that can change the original random orientation to fit this rule?
Thanks
Best answer by ebygomm
If you extract the first and the last z value, you can then test if the last z value is higher than the first and send anything that passes into an orientor to flip the line
Forum|alt.badge.img+54
  • Jun 24, 2020 9:38 AM UTC
  • Jun 24, 2020 11:43 AM UTC
Thanks! It solved correctly my problem!
