Line Combiner - Avoide combining at the intersections
  • Jul 5, 2019 7:27 AM UTC
  • 147 views
jugoslaviaa
Hi all,
I have a road network and I would like to combine them if the road is same, as in the following image . It works perfectly fine with LineCombiner
However lines like in the images are getting combined but I do not want to combine those as there is an intersection. I can fix it with TopolgyBuilder but I want to keep the corresponding id. So therefore i was wondering if there is a way that LineCombiner does not combines if there is intersection like this?
Best answer by jugoslaviaa
The problem is solved. I just needed chance the Junction attribut eto Ignore Attribute Values :)
jugoslaviaa
  • Jul 5, 2019 7:30 AM UTC
Forum|alt.badge.img+54
  • Jul 5, 2019 7:34 AM UTC
Do you have Break Across attribute values set to 'Yes'?
I am trying to solve the same problem, can you please elaborate your solution or share the workbench
