line biulder ends with rejected
  • Jun 19, 2019 2:27 PM UTC
  • 39 views
HEllo,
I would like to build a line from polyygon center points. The coherent polygons have an id (ivv) on which a I want to create a single line.
First I am using a centerPointReplacer to get the centre point of the polygons. After that I am using aggregator, to group the poins by (ivv). Now I want to build the lines, but it gives back rejected even if I set the connection break output to ivv or not. What should be the correct order or parameter setting to get lines from the aggregated points?
Forum|alt.badge.img+54
  • Jun 19, 2019 2:40 PM UTC
You don't need the aggregator. You can use ivv as a group by in the line builder. Note the line builder assumes your points are in the correct order for the line
