LengthToPoint transformer - multiple rejected ports
  • March 24, 2025
  • 64 views
tris_w
Forum|alt.badge.img+8
Upgrading 2023 workspace to 2024.2.  When upgrading or adding a new LenghtToPointCalculator transformer and referencing existing attributes for the X/Y coordinates, FME adds 2 rejected ports to the transformer.  If you then run the workspace you get the error:
Cannot have multiple factories with the same name.  Multiple factories were assigned the name 'LengthToPointCalculator_<Rejected>'
Any suggestions on how to get only 1 rejected port?
Thanks.
Best answer by DanAtSafe
Unfortunately with version 1 of the LengthToPointCalculator, one <Rejected> port will be added for every parameter filled by an attribute value.  This has been fixed for FME 2025.1 via FMEENGINE-85820.  Until that’s available to install, you can avoid the error by connecting just a Junction to one of the <Rejected> ports.
DanAtSafe
Forum|alt.badge.img+22
  • March 24, 2025
j.botterill
Forum|alt.badge.img+55
  • March 25, 2025
If you still have Form 2023 installed somewhere, place the LengthToPointCalculator transformer down in the canvas. Highlight it, Copy to clipboard. Open Form 2024 and paste (the older version).
tris_w
  • March 25, 2025
A simple workaround provided by safe support… connect a junction (or logger) to one of the 2 rejected ports.  Seems to fix the issue.
