Left/Right side bufferer - missing polygon
  • Feb 13, 2019 3:10 PM UTC
  • 172 views
Hi
I have downloaded the workspace 'Buffer On Left or Right Side Only' from the FME Knowledge Centre (https://knowledge.safe.com/articles/20651/buffer-on-left-or-right-side-only.html)
I am following this exactly as I want to create buffers on either the left or right side of a road. I then want to create polygons from these new segments (buffers). I have a separate line (split into 44 segments) which I am using to split the buffer by.
For some reason it keeps missing out one section. I seem to have an overlap at this section when I run the 'Common segment finder'. This then stops the polygonbuilder from creating just one segment.
I am really stuck in how to fix this. Any ideas would be really appreciated. I have attached screenshots within Inspector of the common segment finder 'overlap' and 'no overlap' as well as the outputs of the polygon builder 'polygon' and 'unused line'
Thank you.
gio
Forum|alt.badge.img+15
  • Feb 13, 2019 4:25 PM UTC
@jmac
If the overlap is twarthing the outcome, you could use a lineonlneoverlayer and set "separate collinear segments" to "no" (and preserve paths if needed).
Or intersect, LineOnLine with scs=yes and maybe accept the separate buffer?
Or if overlap is incorrect, remove it?
  • Feb 14, 2019 1:57 PM UTC
@jmac
Thank you! It worked with an intersect, then LineOnLineOverlayer with scs= yes and then fed that into the CommonSegmentFinder. Thank you again
