Launch CommandLine
  • Nov 22, 2018 3:18 PM UTC
  • 42 views
I want to launch Command Prompt from within FME
Specifically, I want to actually launch the command prompt screen.
If I put "cmd.exe" (or a variation) into the SystemCaller, it just runs and logs the text you would see in Command Prompt
I actually want to launch command prompt.
It needs to be launched as it requires user interaction that is not present in the workspace and cannot be fed by a parameter
  • Nov 22, 2018 3:25 PM UTC
Try to simply type "start" in the SystemCaller:
Thank you.
Slightly annoying as I thought I'd tried that!
Yes, it worked
