Keep only the highest value per user
  • Dec 4, 2017 3:48 PM UTC
  • 136 views
A users' progress is being tracked being creating new rows of data, with an incrementing counter in a column like so:
I want to only keep the rows with the highest counter value for each users (A, 5; B,3; etc). So only keep the highlighted rows. How can I do this in workbench?
Thanks!
erik_jan
Forum|alt.badge.img+26
  • Dec 4, 2017 4:03 PM UTC
Have a look at the StatisticsCalculator (group by user, the _max will have the required value).
Use output port SUMMARY.
@mvdorst, there are a number of ways you could do this, but I think the easiest is probably to use a StatisticsCalculator transformer - analyse the counter value/second column, and calculate the maximum, having also included a Group By clause on the name/first column.
Example workflow below:
