keep only distinct values
  • Apr 6, 2020 12:11 PM UTC
  • 1686 views
Hello
After an "attributeKeeper" transformer I try to obtain a selection with distinct value for each row like a "select distinct" sql command. But I fail to find a good solution.
(I didn't find the DuplicateRemove transformer)
Do you know to do it ?
Thanks
Best answer by ebygomm
You want a duplicatefilter, distinct values will exit via the unique port
Forum|alt.badge.img+54
  • Apr 6, 2020 12:17 PM UTC
  • Apr 6, 2020 12:21 PM UTC
Yes. it works... I had not seen this transformer.
  • Apr 6, 2020 12:30 PM UTC
Sometimes transformers are renamed, but the old names are still usable as aliases. To take the example of the DuplicateRemover that was renamed to DuplicateFilter: If you simply type "duplicate" or even "duplicateremover" into the transformer quick add search box (start typing directly from the canvas), you will see the old transformer names in italics, pointing to the new name.
Example:
  • Apr 6, 2020 12:40 PM UTC
Example:
thanks I did'nt know this tip.
