Keep attribute field order after schema scanner
viviancfhung
In FME version 2023.1. We can keep the attribute field order after schema scanner for most of dataset.
But for the attached dataset, we can't keep the attribute field order after schema scanner.
Is any problem in my dataset?
The fmw is attached also
Thanks
virtualcitymatt
Forum|alt.badge.img+38
Ok so as I understand it the schema scanner will preserve order if it knows which order they attributes should be in.
From looking at your workspace the Reader in there was created with from a different dataset with a different schema (the attributes exposed there do not match what is in the actual dataset.
If you add a new reader and use the Dataset and XSD you provided then the SechemaScanner creates the correct order.
Here you can see the difference between when the attributes are exposed vs not
Exposed:
Not Exposed:
Theres a good little video which explains some of this stuff which might help
https://www.youtube.com/watch?v=_MoalhW8zlA&t=212s
viviancfhung
  • August 4, 2023
Thanks, I tried to create reader from the dataset, But the field order can keep only if I select Individual Feature Type. But we can prepare a work flow by dataset. We need a general work flow for all dataset.
What should I modify in this dataset in order to use this general workflow and keep attribute field order
ferhdfme
Forum|alt.badge.img+8
  • June 9, 2025
Hi ​@viviancfhung ,
If you want to preserve the order of attributes even when they are not exposed, you can use this alternative:
  1. After reading the data, use a FeatureReader that only reads the schema (set Features to Read = Schema Features). This way, we obtain the original input schema through the Schema port.
  2. Sometimes, Format Attributes are generated through the Schema port that we don’t need you can filter them using a ListElementFilter.
  3. Add a Sorter and connect it to the Filtered port of the ListElementFilter transformer and also to the input data. In the parameters, sort the attribute fme_schema_handling in descending order so that the first features are those from the schema.
Finally, configure the writer the same way you would with a SchemaScanner.
I’m attaching the workflow so you can take a look.
