Keep association between a generalized line segments and its original segments
  • Dec 16, 2021 3:59 PM UTC
  • 10 replies
  • 146 views
bgeorges
I have polygons on wich I want to calculate some edges infos. However, I want to do the calculation on generalized edges and after bring it back to all orignal edges.
For instance:
Polygon -> edge -> generalized edge -> chopped to 2 vertices lines -> calculate attributes on lines -> merge attributes to original edges
Is there a way at the end I could merge attributes from the generalized line segments to the original line segments?
Best answer by geomancer
Because your Generalization algorithm does not create new vertices, you can use the starting point of each segment for your association.
Extract the coordinates of the starting points of all segments. Left join on these coordinates.
Merge_AttributesThe original segments that do not share a starting point with the generalized sections will have null vallues in the attributes. In the AttributeManager, these attributes are filled with the attribute value of the previous feature (with Enable Adjacent Feature Attributes).
Merge_Attributes_AttributeManager
Forum|alt.badge.img+63
If you add Counter at the start of your process you can give each original feature a unique id (if there's none in the original dataset, otherwise you can use that one) which you can use later on to merge it all back again.
bgeorges
  • Dec 16, 2021 4:18 PM UTC
the counter should be after the chopper, but as you can see there is 2 choppers in the workflow. One for the generalized lines and one for the original.
No, before, so that all features going into the chopper have that id and retain it after chopping
bgeorges
  • Dec 16, 2021 4:27 PM UTC
No, because all chopped segment will have the same id, and that's not what I want.
As you can see in the workflow there is 5 generalized segments which will receive different attributes values and I want to bring those values back to the 8 original segments.
@bgeorges​ You can also preserve and recover original geometries using the GeometryExtractor and GeometryReplacer transformers
bgeorges
  • Dec 16, 2021 7:06 PM UTC
I dont think that can achieve what I need. Maybe my question is not clear enough.
Thank you for your suggestion though.
Yes, so all the chopped segments from line #1 still know they were originally part of line #1, so you can merge attributes back and forth using that id. Isn't that what you want?
geomancer
Forum|alt.badge.img+71
  • Dec 17, 2021 11:02 AM UTC
bgeorges
  • Dec 17, 2021 1:24 PM UTC
Sounds very promising! Thank you for the suggestion! Great idea!​
geomancer
  • Dec 20, 2021 8:35 AM UTC
You're welcome!
2 things to mind:
  • Null values will be overwritten in the AttributeManager because of the use of adjacent feature attributes. So if you want to keep Null values, use a dummy value, and set in to Null later. The NullAttributeMapper may be of use here.
  • Use 'Group By' (on an attribute that is unique for every feature) when you process more than 1 feature.
